J/30 Class Rules paragraph 5.4.1.5 has an "Official Interpretation" annotation that states;
A list of approved replacement winches is available from the Class Measurer.
The list of approved replacement winches will be maintained on the One Design Class Rules forum and updated as necessary.
Table of Approved Winches for the J30 as of 22 August 2011
Winch Power Ratio Weight (lbs.)
Primaries - 2 speed
Barient 25 (Original) 44:1 and 14:1 11.9
Lewmar 43) 43:1 and 15.6:1 12.5
Lewmar 44 44:8 and 13.9:1 12.6
Lewmar 44ST 44:8 and 13.9:1 12.6
Lewmar 44STOR 44:8 and 13.9:1 10.9
Lewmar 40ST 40:2 and 13.2:1 10.7
Harken 40 or 44ST 39.9:1 and 13.5:1 11.9
Harken 46 or 46ST 46:5 and 11.7:1 17.2
Harken 42.2 42:1 and 14.2:1 13.6
Harken 44.2ST 44:1 and 13.8:1
Secondary - 2 speed
Barient 21 (Original) 30:1 and 7.1 9.3
Lewmar 30 30:1 and 7:1 6.4
Harken 32.2 32:1 and 6.8:1 7.3
Halyard - 1 speed
Barient 10 (Original) 7.6:1 3.7
Lewmar 8 7.9:1 3.09
Harken B8 7.5:1 2.31
The table is available to download and print via the attached Word document.
Charlie Stoddard
Falcon #229
LChristy #12217 08/22/11 02:01 PM
The Lewmar 40ST has been added to the approved list for primary winches
Charlie Stoddard
Falcon #229
J/30 #12721 12/13/11 05:57 AM
S Offline
I don't see a Lewmar 44ST winch listed on the manufacturer's website. Did you mean the Lewmar evo45ST?
sonskyn #12722 12/13/11 07:50 AM
with all the new models that have been introduced I will update the list The evo 45 will probably fall in with it
Charlie Stoddard
Falcon #229
cstoddard #12723 12/13/11 12:00 PM
S Offline
comparative data
Approved:
New:
Lewmar 45ST Evo 44.8:1 and 13.9:1 7.2kg (Black/Grey Alloy)
Lewmar 45ST Evo 44.8:1 and 13.9:1 9.7kg (Chrome Bronze)
sonskyn #12738 12/17/11 12:11 PM
S Offline
the Lewmar 40ST would be a replacement for the secondary and not the primary winches, if considering Lewmar: the hole pattern for the Lewmar EVO 45ST does not match the Barient25; the "Fast Fit" idea was never implemented, no studs supplied. Winches are mounted in the conventional manner.
sonskyn #12741 12/18/11 05:41 PM
The 40's are not approved for use as a secondary they are two large Power ratio's are to high
Charlie Stoddard
Falcon #229
cstoddard #13616 06/13/12 01:31 PM
No consideration on Andersons?
Binnacle.ca is having a smoking sale right now beinging the price down to the same as the aluminum Harkens and Lewmars
NaturalHigh #13627 06/15/12 09:03 AM
I see no reason why we Anderson's can't be approved and added to the list as long as they are in the same power ratio area as the Lemars and Harkins
let me know which one you are looking at and I will review
I did put a new pair of the Harkin 40.25 Self tailers on this year and the crew love them tons of power
Charlie Stoddard
Falcon #229
cstoddard #13628 06/15/12 05:47 PM
Anderson 40ST is I think the most comparable. There is standard, standart self tailing, and full stainless self tailing.
Winch Model 40 ST
Drum "D" (mm) 75
Base "B" (mm) 152
Height "H" (mm) 174
Line entry "L" (mm) 71
Line size (mm) 8-14
Weight (kg) 4.9
Gear Ratio 1st speed 1.3:1
Gear Ratio 2nd speed 6.0:1
Power Ratio 1st speed 8.5:1
Power Ratio 2nd speed 39.5:1
Moderated by  LChristy
