Posts: 114 |
I need a Prop Strut for my 1979 J30, Hull #25. I have been told that there are several different struts that were used on the J30's over the years, so I need to be sure that I find one that will fit my boat.
Phil
take picture and post. also measure the WxL of the base rectangle. that may give us a better idea of just how different they could possibly be.
Posts: 114 |
Just reporting what the repair yard said. I would guess that the prop shaft diameter will make a difference too (3/4" v. 1").
Once the old shaft is on the boat I'll try to get a photo posted.
OK that may be your repair guys winging it. the 1" shaft I'm thinking was optional starting in ~400 series and standard in the hull 500 series.
Posts: 2,685 Likes: 1
Posts: 2,685 Likes: 1 |
Hull 348 came with a 1" diameter shaft
Posts: 381 |
Can you let me know what the bolts look like when they come out and if you can tell how they are mounted in the hull? Mine is loose and I am debating drilling all the way through the hull and mounting a metal plate with nuts on the inside.
if you decide to reinforce using a backing plate ... I suggest G10 as an alternative to metal. Doing a quick grind and epoxying the g10 inside the hull before redrilling. This will give a pretty solid base for the strut.
I'm thinking that in construction they attached the strut bolt nuts on the inside ... and then ran a layer of thickened resin over the area to "seal" it? Let us know if this guess is close when you get there.
