Posts: 25 |
done ! before : ![[Linked Image from i49.servimg.com]](http://i49.servimg.com/u/f49/10/09/29/62/dsc00510.jpg) ![[Linked Image from i49.servimg.com]](http://i49.servimg.com/u/f49/10/09/29/62/dsc00511.jpg) ![[Linked Image from i49.servimg.com]](http://i49.servimg.com/u/f49/10/09/29/62/dsc00512.jpg) after : ![[Linked Image from i49.servimg.com]](http://i49.servimg.com/u/f49/10/09/29/62/dsc00513.jpg) ![[Linked Image from i49.servimg.com]](http://i49.servimg.com/u/f49/10/09/29/62/dsc00514.jpg) And, in the same time, we change winches to Lewmar self-tailing 44. It was not the same holes positions, so I need to full the hole with epoxy and drill new hole. It was my first work with epoxy, I was too much busy to takes pictures while working ! I use this very good technic : http://www.pbase.com/mainecruising/sealing_the_deck![[Linked Image from i49.servimg.com]](http://i49.servimg.com/u/f49/10/09/29/62/dsc00515.jpg) ![[Linked Image from i49.servimg.com]](http://i49.servimg.com/u/f49/10/09/29/62/dsc00516.jpg) ![[Linked Image from i49.servimg.com]](http://i49.servimg.com/u/f49/10/09/29/62/dsc00517.jpg)
Marie,
What did you end up using under the track? Is that plastic, wood or the old track? Nice winches!
Posts: 25 |
Hi,
It's old track. We put it back, and put back some of the screws (minus 8 screws). Then we put the new track with sliding screws (8 screws, 3 for each end and 2 in the middle) in the 8 remaining holes. It was difficult to put these 8 screws right down in the holes, but finaly we succeed.
Ok - that should work fine. You'll notice that there is a small space between the track and the cutout area where the track is mounted. I found this collected dirt, shrimp, grapes, cheese, chips and anything else you consume. That is one reason I ended up filling in the area completely with the 1" x 3" wood strips.
Posts: 162 |
Félicitations Marie. J'aimerai faire ces modifications à mon bateau aussi... un jour. Merci pour l'avoir si bien rechercher et documenter.
Translation: Congrats Marie. I'd like to one day make the same modifications to my boat. Thanks for well researching and documenting the process.
