sonskyn #14023 09/25/12 08:40 AM
G
G Offline
Originally Posted by sonskyn
What do you mean by a "blocker"? Is it a rope clutch to take up the jib sheet when the secondary winch is temporarily needed for other purposes?
Yes this is what I meant - more of an horizontal jammer - when you do not have to guide the line in... I remember seeing some used to switch between genoa and spinnaker sheets on primary - when you do not have secondary winches for the spin sheets.
-- Georges
Rhapsody #348 #14024 09/25/12 08:46 AM
G
G Offline
Thanks Bill,
I understand the need fordiscussion and eventually vote... It is more like a pre-discussion to gauge the interest and gather early feedback. I do not yet race much in OD, and was looking for a cruising extension still in line with the OD race spirit more than a racing competitive advantage :-)
-- Georges
Patrick Peters #14025 09/25/12 08:50 AM
G
G Offline
John, I am also very much interested by more picture of your pocket dodger, as well as your reacher (custom? small boat asymmetric?) and its tack setup.
Cheers,
-- Georges
sonskyn #14026 09/25/12 09:46 AM
Patrick/Georges
To keep cost down I used aluminum tubes on the dodger. Bought them used and fit them myself. Then a canvas guy came to the boat to make the cover. I use it in solo/double-handed races and cruising. Makes a huge difference on cold night or for some needed shade. It is off the boat most of the time.
That is my A3. AirX 750. These shots are during the Solo Mac this year and I had it up the entire first day. Great reaching sail, and must be flown from the pole. I run the sheets inside for both of my chutes and works great. It is 85% of the class chute size, flatter, and asym.
John
Madcap 358
sonskyn #14031 09/28/12 11:05 AM
S Offline
It took Neil Thurston less than 7 days from first enquiry to completed installation! I am very happy with the outcome.
