1,146,073 Dacron Main
212,948 Ananda's Refit
mjr
Offline
Greetings,
A number of potential rule change have been drafted for consideration during the upcoming Borad of Governors meeting which will be held on Oct 18 in New Orleans. Below is the listing for your consideration. Please get back to me with any strong opinions on any of the items so that I can make sure I understand your concerns before I issue my vote. As it stands, I have no objections with any of the changes as presented, and favor Case 2 in the advertising question.
Mark Rotsky
Paragraph 5.4.1.11 rules - existing
5.4.1.11 Removal of the Jib Tack Horns and replacing them with a single shackle attached to existing hole of bow fitting.
Paragraph 5.4.1.11 rules - proposed
5.4.1.11 Removal of the Jib Tack Horns and replacing them with up to two shackles attached to existing hole of bow fitting.
Paragraph 5.4.1.12 rules - new rule proposed
5.4.1.12 Cowl vent fitting on foredeck is optional and maybe removed.
Paragraph 5.7.4.4 rules - new rule proposed
5.7.4.4 Use of the Rig-Rite Stainless Steel Jib Box Assembly: K-10658 (supplied as original equipment on earlier masts) or Aluminum Jib Box Assembly: K-11597-1 (supplied as original equipment on later masts) is authorized. The intersection point of the forestay fair extension and the mast front face shall be the same height and forward extension from the mast face so that the position of the headstay measurement point is identical in accordance with rule 5.2.8.1 and the J/30 Mast Specification standard drawing provided in the class rules "J/30 Basic Specifications" section.
Paragraph 5.8.1.2.1 rules - new rule proposed
5.8.1.2.1 Use of a bare metal head stay and hanks on jibs.
Paragraph 6.9.2 rules - existing
6.9.2 The North American Championship shall consist of a maximum of seven (7) races.
Paragraph 6.9.2 rules - proposed
6.9.2 Deleted
Note: Although not part of the class rules, a set of guidelines for organizing the North American Championship have been issued on the J/30 Forum and will be updated to state:
1. The regatta is sailed over three days - typically Friday, Saturday and Sunday. The organizing committee should include in race documents a schedule that lists the latest time a race may be started each day so that events planned after racing may be scheduled, and provide race organizers maximum flexibility to run races each day as allowed by the weather conditions. For specific J/30 Class Rule information, refer to http://j30.org and select "Class", "By-laws, Rules, Specifications" from the menu.
Advertising
A vote will be taken so the rules reflect either Case 1 (Advertising Allowed), or Case 2 (Advertising Restricted). Advertising restricted is basically the same as current J/30 class rules. This link is the ISAF Regulation 20 reference.
Case 1 - Advertising Allowed:
No changes required in class rules. Advertising becomes permissive on 1 January 2013 when the ISAF transitional period expires on 31 December 2012.
Case 2 - Advertising Restricted (similar to current rules):
The following paragraphs are added at the end of the Class Rules:
6.10 Advertising
6.10.1 Class rules prohibit the display of advertising, except as may be required by the Organizing Authority for class events in accordance with ISAF regulation 20.4.1.
6.10.2 Manufacturer's and Sailmaker's marks shall always be permitted in accordance with ISAF regulation 20.7
Mark Rotsky
Nemesis 435
NBYA - Narragansett Bay Yachting Association
The Regional Sailing Authority for Narragansett Bay & Adjacent Waters
The J/30 SNE District is an NBYA One Design Class member
NBYA Website
NBYA One Design Page
NBYA Store
Bill and Mark:
I'm in favor of all of the changes. Moving ahead.
Bob Rude
5.8.1.2.1 - Hanks on headstay - I know it states somewhere in the rules that the standing rigging can not be altered in material from the original supplied by the manufacture_ but I think "bare metal" opens the door for interpretation. I think it should read "bare 1x19 wire".
Corey,
That is a good comment. The proposed wording has been updated and now reads:
5.8.1.2.1 The jib luff groove system may be eliminated to permit the use of hanks on headsails.
Moderated by  mjr
