1,145,990 Dacron Main
212,777 Ananda's Refit
#14302 12/06/12 02:15 PM
S Offline
Does anyone know the angle need for a depth transducer next to the mast. The options are 0 deg, 12 deg, or 20 deg. I am replacing the existing with the St 60 plus system.
My through hull xdcr is 0 degrees even though it is left of center by about 1 foot. Probably doesn't make much difference since it pretty much agrees with the charts where I sail.
Here are some early install pictures of the TackTick (Airmar made) transducers when I did the upgrade. Bottom view was before bottom painting.
Right of picture is forward on boat.
[Linked Image from j30.us]
S Offline
Thanks for the info I'll order a 0 degree.
