October
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
1,193,899 Dacron Main
231,244 Ananda's Refit
Members1,064
#14509 02/25/13 09:50 PM
I need a Bow Pulpit to replace the one Sandy twisted. Can anyone provide any assistance?
John
Presto #436
203-509-1469
dennejo #14515 02/26/13 04:30 PM
I had one made at Whitewater Marine in Port Huron, MI. They have a measurement guide on their website. I used the opportunity to build mine as double rail. They did a nice job for me.
dennejo #14567 03/12/13 06:35 PM
B
B Offline
Just sent you an email about this. There's a used bow pulpit in Chicago.
Conundrum #14577 03/24/13 03:22 PM
Would you send me a picture of it. My bow got crunched in a race last month.
Mark
Mark Swatta
Las Brisas - Hull #498
Does anyone have the measurements? I have attached the measurements which Waterline Systems needs to have a new one built.
JDD
Attached PDF document
John - I'm reinstalling the pulpit on Rhapsody tomorrow and will fill in the measurements on the sheet. I'll post this for all to use.
dennejo #14628 04/13/13 08:16 PM
Attached is the measurement sheet based on the bow pulpit installed on Rhapsody. It may be a good idea for someone to check this against their boat just to make sure the dimensions recorded are the same.
Rhapsody #348 #14629 04/14/13 07:01 PM
I have a different set of numbers for my 1984 J30, I also had the luxury of a scratch deck, newly recored, to work with.
My fairleads dictated where the bases should be and I did my best to replicate the original placements. I moved them outboard a bit but not fore or aft.
Here are my measurements. Mine is a double rail pulpit. I hope I am not confusing the matter for you.
Pic 3056 is the original layout.
Pic 3810 is new layout.
When i recieved my Pulpit from Whitewater, i was worried that it did not fit correctly as it did not sit flatly on the deck. However at their urging, i wrestled it into position and bolted it down. It IS fine even if not perfect. It is a replacement on a repaired deck and there were bound to be some imperfections.
2 years later and I never see the errors of the repairs anymore. I love this boat!
Rhapsody #348 #19453 06/02/25 09:20 AM
W Offline
Bill, the measurement sheet is great. Do you have any idea what the weight might be?
0 members (), 205 guests, and 4 robots.
