1,203,266 Dacron Main
233,940 Ananda's Refit
#14708 05/02/13 09:00 PM
What is the height of a J 30 from the bottom of the keel to the highest part of the deck/pulpit?
Thanks in advance for any info.
Regards,
CB
just enough so that you have to use a low boy to trailer it. then think you are just clearing what a standard trailer truck will on overpasses.
mine came down 1500 miles without taking the bow pulpit off.
I'm assuming that's what kind of info you are looking for.
Sorry - don't know the demension but when the boat is on my trailer the bow pulpit is lower than all the bridges between Mich and New Orleans. if I recall, with the boat on the trailer, the keel sits about 6" above the ground
I shipped it on a low boy trailer from California to Michigan with the pulpit on the boat. the boat arrived with the pulpit still on the boat
I am 13'2'' on my 3 axel trailer with the mast under the bow pulpit (measured from the bow pulpit). Trailer is oversized and keel is blocked up to fit the stands. With shorter trailer I would sit lower.
John
Madcap 358
I am ~13'3" with the mast support of my Triad J/30 trailer holding the mast above the pulpit. This would drop a bit if I the aft end of the mast was more than 3" above the stern rail.
Chris
Blitz 357
