1,179,623 Dacron Main
225,981 Ananda's Refit
#14731 05/12/13 08:33 PM
A Offline
Does anyone have precise dimensions on the cabin top opening through which the mast is lowered to rest on the keel?
I have the kenyon mast dimension here.
[Linked Image from rigrite.com]
But - how closely does it fit, and how closely does the shape match?
Looking to perhaps change my strategy around holding the mast when it's lowered, to using a U-section on top of a post down to the keel instead of a foredeck A-frame.
The opening size varies over the production run of the boats Most have about a 1/2" of clearance around the mast
Charlie Stoddard
Falcon #229
Don't count on the opening being centered and symmetrical. I found this out when I centered the top of the mast over the bottom of the keel when the boat was out of the water. I poured Spartitite and found the mast was almost in the extreme stbd side of the cutout, leaving a larger gap on the port side. Fore and aft was about right when I set the front of the mast at 3505mm (11 ft 6 inches) per rule 5.7.3
S Offline
I had the exact same result centering the mast relative to the chain plates, because it looks so odd I double checked a couple of times.
A Offline
Thanks everyone.
0 members (), 33 guests, and 2 robots.
