1,179,634 Dacron Main
225,988 Ananda's Refit
I ran into this problem this summer when I rehabbed Vee Jay 2's boom ... the forward block sheave was locked solid. Checked Vee Jay today here in Naples and not only was the sheave locked solid being compressed by the becket ... also was rigged as a 2:1 instead of a 4:1. The Kenyon block looked under spec'd and is probably a problem for anyone who hasn't checked it out.
Naurally there are 3 SS screws into each AL boom end fittings. Two I was able to unscrew, three broke, and one was finger tight. Followed old practice of grinding smooth ... redrilled a half inch away, tapped up to 1/4 in. and reassembled.
[don't really need to open up aft end of boom as the needed access is at the mast end of the boom]
S Offline
I replaced the blocks inside the boom with Harken 40mm Carbo blocks and thru bolted the gooseneck end, two seasons and no problems to date.
Wish I'd read this when it was first posted. Took my boom apart today to find both blocks totally seized... No wonder we've been struggling with it. I look forward to my APS package in the mail and more beautiful sail shape this summer!
Michael
The original specs used only a two to one advantage I changed mine to a 4 to 1 reduction years ago makes a huge difference in getting the outhaul set when under load If you are taking the boom appart also change out the stainless wire back to the end of the boom its cheap and a real PIA to change if it breaks
Charlie Stoddard
Falcon #229
I also had problems with the blocks being seized up. I added an extra block to the system to get 6:1. Perhaps a bit overkill, but very easy to adjust in heavy air. A few pictures before putting everything into the boom are at Hullabaloo Outhaul Repair.
Tom Heinrich
Hullabaloo #443
Hullabaloo - J/30 Hull #443
Hullabaloo is on target, though I have a few quibbles. Counting the turning block where the purchase exits the inboard end of the boom the original setup was 4:1. Adding 2:1 makes it 8:1 which is plenty.
Since you are updating, you might replace the old school wire tail with a 1/4" spectra single braid like Amsteel and use the same line for the 2:1 part of the purchase which takes the highest load. For the 4:1 part try 5/16" double braid like Sta-set which is easy on the hands. As noted in a previous thread adding a Ronstan RF5 Swivel 180 Cleat allows the crew to adjust or release the outhaul from either rail.
So I'm trying to upgrade the outhaul on 526. Vic did the 4:1 thing a while ago, and the blocks are fine. I think it could use some more purchase. I like the idea of the system described by Hullabaloo, especially since I have block which should do it. With the straight Hullabaloo modification, the wire to the outhaul seems too long, so maybe this is a time to change to spectra for that line. Question: How much outhaul movement at the clew do I need?
Michael
Michael ... remember on the Vee Jays we lead the outhaul back to the cockpit and in line with a winch and cleat. The only thing we do from the middeck is the pole lift and in lighter conditions the spin halyards. That said I'm thinking 16 in. is probably more than enough wire out the end of the boom.
[Ann M was with us this weekend ... driving on Sat. and playing with us on 420s and Precision 15s on Sun. ]
Thanks Vic.
I'm undoing all your good work and running as many lines to the mast as possible. I'm settling in on adding an additional 2:1 by cascading the 4:1 (a la Hullabaloo). Vang too, will be operated at the mast.
The goal is to keep my pit person (wife Teri) out of the cockpit. (Not that she's not welcome there anytime).
Michael
The outhaul only needs to move about six, maybe eight inches at the clew from bone-tight to fully eased.
0 members (), 279 guests, and 23 robots.
