1,179,999 Dacron Main
226,162 Ananda's Refit
After 30+ years, one of the ends on our Spinnaker pole has failed. Anyone know where I can purchase a used replacement part?
Dave (aka Zephyr)
Dave,
From the Equipment Suppliers page on the class website, check the Rigrite page for 2.5" spinnaker poles. You'll need to measure the diameter of the pole and determine the correct end fitting you have. The page I referenced is for 2.5" diameter poles. Not having the pole handy to measure, use this page to select the correct diameter, then click on the diameter to get the page with the parts for that pole. You then can scroll down to standard end fittings. I think the end fitting on the standard pole is this style.
[Linked Image from rigrite.com]
Dave,
Not sure if you solved this problem.
I have a class aluminum pole. One end no longer trigger locks but it works. Has bridle set up. Let me know if this would be of interest.
Rob
Rob thanks I found an end on eBay for $158.44. My poll is 3" in diameter so needed part - PISTON END Forespar TR-300 w/Cable-Fits 3" Tube
ebay listing
I have the same problem now (open end broke yesterday during a race), Dave do you still have the pole you were mentioning on Oct 16 ?
Beppe
beppe, yes I simply puchased a new end on eBay and repaired the pole - special thanks to Glen Tonguis.
Looking for another PISTON END Forespar 300-EF for 3" spinnaker pole, Anyone have one for sale by chance?
