For Sale: 1987 J/30 hull #546 in Redwood City, CA
Boat DetailsLOA: 30'
LWL: 25'
Beam: 11.18'
Draft: 5.25'
Displacement: 7,000 lbs.
Ballast: 2,100
Max. Bridge Clearance: 48'
Cruising Speed: 6.0
Max. Speed: 6.5
Engine: Yanmar 2GM20F (1987)
Horsepower: 15
Engine Hrs: 26.9 (new meter)
Fuel: Diesel
Fuel Tank: 14 gal. (stainless steel)
Holding Tank: 14 gal. (polypropylene)
Water Tank: 18 gal. (polypropylene)
Hull Material: Fiberglass
Keel: Fin
Rudder: Transom-hung
Designer: Rod Johnstone
Builder: TPI
DescriptionThe last J/30 built (hull # 546). The J/30 continues to be a great cruiser and a very competitive PHRF racer. This model has the highly desirable 5 berth interior layout with L shaped galley and 2 burner propane stove. This model also features cockpit seats with contoured backrests and large storage locker to port. It's an opportunity to purchase a truly multi-purpose boat at a very reasonable price.
AccommodationsStarting forward, you have a large V-berth with partially enclosed shelves on both the port and starboard side above the berth. Aft to port is a head with sink and vanity. Across from the head is a hanging locker. The main bulkhead is solid fiberglass with an ash veneer that faces the main salon area. In the main salon area you have two settee berths with storage behind the backrests. Above each settee is an open shelf with enclosed cabinets at each end. There is a removable centerline drop-leaf table. On the starboard side aft of the settee is a chart table with an icebox below a sliding surface. Below the chart table is a bottle storage swing-out cabinet. Aft of the chart table is a large quarter berth. Opposite to port is an L-shaped galley.
GalleyThe L-shaped galley has formica counter tops with built-in utensil and dish racks. Large item storage is below the Force10 two-burner propane stove and dry goods storage is behind and in cabinets above the stove. Additional serving or prep space is available from two fold-down tables. The stainless steel sink has manual and pressurized water with soap dispenser.
Electronics2 Ritchie BN-202 bulkhead mounted compasses
Horizon MD100 Depth & Speed
Raymarine ST60+ Wind Speed & Direction
Icom IC-M59 VHF
Garmin 120XL GPS
Raymarine ST2000+ tiller pilot
Pioneer DEH-505 AM/FM CD with speakers in main salon & cockpit
Samsung LCD HDTV & DVD player
ElectricalStandard J/30 AC & DC circuit breaker panels
Starting Battery Group 24 M7 2013
House Battery Group 24
Charging & Load DC ammeters
Battery charge state indicator
2 battery isolation & paralleling switches
Marine Air reverse cycle A/C (120VAC)
GFCI AC receptacles
DC receptacles
DC Cabin Lights
Navigation Lights
Water Pump
Automatic Bilge Pump & Cycle Counter
Propane Shut-off Valve & Indicator
Deck2 #27 2-speed self-tailing, & 2 #21 2-speed Barient winches
Jib and genoa tracks with cars
Double life lines with bow and stern pulpits
4 bolt mooring cleats
Adjustable mainsheet traveler
Adjustable backstay
Boom Vang
Cunningham
Spinnaker pole with stanchion storage
Halyard stoppers
Manual bilge pump in cockpit
Tiller extension
Anchor storage locker
SailsMainsail good condition
Additional Shore main in fair to good condition
#1 Shore mylar in good condition
#1 Scott mylar in good condition
#2 Shore in good condition
#3 Shore in very good condition
.75 oz. North spinnaker in good condition
1.5 oz. Horizon spinnaker in very good condition
Mainsail cover
Harken Mark III Roller Furling
Harken #254 Lazy Jack system
Safety GearLifesling
Life vests (6)
2 Boarding ladders
Fire Extinguishers (three, type B-1)
First Aid kit
20# Danforth and 24# plow anchors each with chain and rode
Boat ColorsHull is dark blue painted in 2012
Red boot and cove stripe 2012
Bottom barrier coated in 2000, painted blue in 2012
Topside gray Awlgrip painted in 2006
excellent condition, well maintained, last one made.
$29,000.
(954) 325-3768,
ecmx39@gmail.com
