Thinking about a new prop for J30 #456 1983. Yanmar 2GM
Existing Martec is very worn and I'm told it is also very inefficient. Looking for more push in a headwind so can maintain at least 5 knots. Still want folding prop as lots of pots in Penobscot Bay and still to sail fast.
[Need the gear ratio so I can get a quote from suppliers. Looking at Flex-Fold - any thoughts or recommendations?
Thanks!
Tom Hildreth
Kingfield ME
Check the modelof your transmission. Standard Yanmar Kanzakai ratio is 2.62 to 1
Thank you
Tom H
alx Offline
Ananda has a 14" 2-blade feathering Max Prop which works beautifully - especially in reverse where it really shines in comparison to the Martec. A folding prop is likely better if you have lots of pots around though.
Tom - The stock prop on my J/109 is a 2 blade Flexofold. This is the installation sheet that has some good pictures. Performance on the J/109 is very good ahead and astern. Becuase it is geared, you don't need to position the shaft as you do with the Martec folding prop to align the blades side by side for optimal feathering.
Installing anything other than the Martec on a J/30 is not in accordance with class rules for OD racing.
Southeast District Governor
I had to replace my prop this year!
Both sides of the Martec Prop had cracks.
Potentially caused by a line I caught several years ago...
I replaced it with a new one and the folks at Martec were able to rush the job so I could get to the St. Augustine Offshore Series...
Skimmer J30 Prop
Skimmer J30 Prop
Graeme Nichol
Skimmer
OBYC
