#16202 04/13/15 12:34 PM
Mine is leaking and I have purchased a replacement. Does anyone have any tips on removing the old tank and installing the new?
Blue Meanie J/30 #485
That is a head scratcher Steve, I will take a peek at mine tomorrow. Is your replacement the same shape and size?
Yup!
Steve, I removed mine to clean it and had to cut away the fiberglass tabs holding it in place. With a bit of effort the tank then slid aft and out the storage cutout. I left the vertical section of the tabs in order to thru-bolt some new L-shaped plywood tabs that now hold the tank in it's place. Sam
That is kind of what I thought would be the way to do it. Thanks!
U
U Offline
Steve, any suggestion for this project, since you went through it already. What mfg did you go with for the new tank? I Stopped up the drain holes from the engine and diesel compartment with oilsorb sheets to try to confirm the source is the tank.
I‮m starting to see diesel in the bilge and it doesn‮t look to be coming from the engine. I‮m assuming, for OD rules, we can‮t install a plastic or smaller tank?
I actually found a used tank that was off a boat being "parted out". Pretty sure you have to stick w metal tank for OD, but you might want to ask LC. I did locate a fabricator who could make a new tank as I recall-I will see if I can find the info about it.
