Posts: 97 |
Hi all-
Tried searching a few different terms but couldn't find a thread about this. Has anyone replaced their bowmar hatches with Lewmar (Ocean or Medium Profile)? If so, does anyone know the specific models/sizes/config?
I vaguely recall reading something some time ago that one of the lines will drop right in with minimal grinding/filling in tne non-flanged config...
Also - I believe the main salon/head hatches are the Lewmar 10 and the foredeck the Lewmar 60... Would be great to confirm if anyone has done this switch.
Thanks! - Jeff
- Jeff J/30 #426 - Watusi
Posts: 126 |
Hi Jeff,
I replaced the 2 small Bomars with (size 10, I think) Low Profile Lewmars, which were the last 2 on clearance from Defender. I needed to cut out the deck opening about 3/8 on all sides, but it was all in solid glass - no core. I sanded and painted the exposed deck edge below the frame for a pro installation look.
With compound and a polisher the ugly forward Bomar cleaned up nicely. I did not remove the light from the plastic frame and grid, because I was afraid it might leak after I "fixed" it.
Silicone was used to bed all of the hatches - leak proof the first time.
This was probably one of the easier jobs on my long list this year...
Regards,
Jeff
Posts: 649 |
You can replace them with out cutting the deck. You need the Lemar without a flange. They mount flush to the deck. Not sure if the low-profile comes without a flange. But they are perfect matches with the stock opening.
DB
Posts: 97 |
Thanks Jeff and David! That helps - appreciate the wisdom. Time to do a final measure and place an order.
Thanks! - Jeff
Posts: 13 |
Jeff -- If you'd be so kind as to let me know what you ordered, and more importantly, if they fit, I would appreciate it.
Good luck, Brian
Posts: 649 |
I used the Lewmar Ocean 10s without the flat base to replace the old small Bomars. I had to fill the old holes with epoxy and then re-drill new holes for the Lemar's. Not a hard job at all. http://www.lewmar.com/products.asp?id=8016&lid=25097DB
Posts: 162 |
Thanks! - Jeff Jeff how did this work out for you? Specifically which hatches did you end up ordering and how smooth was the installation? Regards, Dominique
Posts: 8 |
I installed the Lewmar Open Ocean hatch without flange on Mithril last summer and it has been great. Easy job. I used 4200 and also had to fill in old holes and redrill.
Justin Byrne Mithril #495 Marblehead
Posts: 162 |
I installed the Lewmar Open Ocean hatch without flange on Mithril last summer and it has been great. Easy job. I used 4200 and also had to fill in old holes and redrill. Was this for the V-berth hatch or the small head/salon hatch? Either way which size did you use. My hatches are done and I want to replace them this winter. Just need to get a handle on which hatches to order After looking at the different Lewmars this weekend I would like to try the low or medium profiles versions but I'm not sure if they'll fit without modifying the deck. A little more research is required I guess.
Posts: 8 |
It was the V Berth and I used the lewmar ocean 60 without a flange. From prior posts the other hatches would be the 10. I do not know if the lower profile hatches fit as well. I am hoping to replace the two smaller ones next season.
