Behind the house panel, these terminal blocks accept the returns from the fuses and will distribute power to all house loads:
![[Linked Image from i.imgur.com]](http://i.imgur.com/2zVOGxz.jpg)
The AIS system boots up to prove that the new wiring works!
![[Linked Image from i.imgur.com]](http://i.imgur.com/uKJuZlD.jpg)
The house panel has a Blue Sea VSM422, a Vessel System Monitor that keeps track of battery voltage, state of charge of the house battery, current draw, AC voltage and draw, fuel and water tank levels, and the bilge pump operation. Its connector is here:
![[Linked Image from i.imgur.com]](http://i.imgur.com/usYjZbu.jpg)
House circuits that need to cross to the other side of the boat dive back under the quarterberth to this terminal block, where another segment will cross in front of the engine:
![[Linked Image from i.imgur.com]](http://i.imgur.com/RbzFJ50.jpg)
The panel is getting pretty busy!
![[Linked Image from i.imgur.com]](http://i.imgur.com/K8l7SJk.jpg)
I figured this wall would be a good spot for the ICOM M802 Single Sideband radio control box:
![[Linked Image from i.imgur.com]](http://i.imgur.com/iA7OSnz.jpg)
As I finish running circuits I can close up some of the raceway:
![[Linked Image from i.imgur.com]](http://i.imgur.com/rrZMW04.jpg)
![[Linked Image from i.imgur.com]](http://i.imgur.com/OGtB0EY.jpg)
Next, I wanted to mount a chartplotter by my chart table for indoor navigation and planning. I decided to put it on a swivel arm so it can be adjusted to suit whoever's using it, either standing over the table or sitting on the quarterberth. I think it came out looking rather nice:
![[Linked Image from i.imgur.com]](http://i.imgur.com/rBreFCm.jpg)
![[Linked Image from i.imgur.com]](http://i.imgur.com/vWVuae8.jpg)
