Posts: 34 |
Fellas: I'm assuming the plumbing strap setup is not the correct way this is supposed to be setup-- See attached photo, please. Can anyone please help me with a photo of a properly equipped boom end fitting or offer any other advice on rehabbing this item. joe ![[Linked Image]](https://j30.us/ubbthreads/ubbthreads.php/ubb/download/Number/2145/filename/20170407_111205e.jpg)
Posts: 2 |
Joe, there should be a pulley on each side for reef lines, the centre pulley is your outhaul.
Looks like the pulley in the picture is gone and replaced with a washer.
bob
It should look like this as shown on the Rigrite page. ![[Linked Image from rigrite.com]](http://www.rigrite.com/Spars/Kenyon_Spars/_derived/E-boom.html_txt_d-43006a.gif)
Posts: 34 |
Thanks for the image and the link. So, now I am looking for the Cams-- I refuse to purchase anything further from RigRite. I will fab the sheaves and stainless plates. The cams are beyond my capabilities. If any has the parts, I'm interested.
Gooseneck Reef Cam - Port: K-11246P: Gooseneck Reef Cam - Starboard: K-11246S: New-Style Cast aluminum Cam lever fits on 3/8" bolt and has recesses for special friction-lock washers, K-10862 (2 included). Specify Port or Starboard.
Posts: 164 |
Hey man,
Screw the cams. Not wanting to give the jerks at rig rite my business and also being without cams, I lead the reef lines over the pulley, down to a block at the base of the mast, through the deck organizer and back through the clutch. Now I can take on the reef line on the cabin top winches and release the clutch without leaving the cockpit.
Posts: 34 |
I don't have the sheaves either!! What I have is jury-rigged poo! I may make new sheaves and plates and see where it goes from there.
Posts: 42 |
Hi there Bill, if you can think back, did you find that the new style reefing hardware was an improvement over the original setup?
That was the original style I used.
Posts: 42 |
