#17284 04/24/17 04:23 PM
S Offline
Hi,
It looks like my boat has the original seacocks which I believe are seized.
Correct me if I'm wrong but these are all one piece, valve and threwhull is this correct? (See URL for pic)
https://goo.gl/photos/EruuvaACKNBxAE596
Sean #17288 04/24/17 11:20 PM
Hi Sean,
Assuming that the bronze hasn't turned pink deep into the metal, these Perko seacocks are rebuildable. The parts needed are:
080500599B Perko Repair kit - 3/4
080500599C Perko Ball Valve Stem (driver)
which are available by special order from Jamestown Distributors, Yacht Supply Depot and others.
I had good luck rebuilding mine, and found that the replacement parts were better than the original.
-Chris
Sean #17290 04/25/17 08:25 PM
you may think they're seized... a bit of lubricant and a pipe for leverage might disagree...
