1,179,623 Dacron Main
225,981 Ananda's Refit
#17596 01/07/18 09:53 PM
P
P Offline
Hi,
I have OD set up J30 and I want to have her registered for PHRF her sails are the standard OD North Sails 2002
Can someone tell me what the following measurements are?
ACTUAL RIG AND SAIL INFORMATION
Measurements (in feet and decimal format) should be completed as outlined in the PHRF BC Rules.
I__________ISP__________ H__________ J___________ JC__________ SPL _________ WPL__________
HEADSAIL: LP ________ LLJ ________
MAIN : HB________MGU_________ MGM_________ Main P _________ Main E __________
SYMMETRIC SPINNAKER: SLE ________ SLU_________ SGM________ SGF_________
Thanks
Paul
Attached is a PHRF-NB form from 2014 - the final year I owned Rhapsody. It has most everything you need. If you look on the J/30 website menu you can mouse over Info and click on Official Specifications. There is additional information in the class rules available if you mouse over Class then click on By-laws, Rules & Specifications.
Sail dimensions should come from your sail maker.
Edit: ps look at World Sailing Equipment Rules of Sailing ("ERS") for definitions of the measurements
Attached PDF document
P
P Offline
Thanks but its missing all the sail measurements that I need
Which sail maker made the sails? They have that data, or you may take it to any sail maker to be measured.
0 members (), 33 guests, and 2 robots.
