Posts: 393 |
I made new hand rails last summer. You can have my old ones no charge. I will be in Newton for Easter. I can bring them with me if you want them
Posts: 232 |
Posts: 232 |
I may have the stove but not the tank. Interested?
Posts: 37 |
Hi Mark, Just following up on the mainsail cover (sort of fell off the radar screen there for a bit). Did you determine if yours is in OK shape - and, if so, how much you'd want for it? Thanks! Bill Veno
Waltzing Matilda
Posts: 232 |
Haven't found it yet. I know I have it, just not sure where it is. I will look some more.
Posts: 34 |
Jib furling?
Also, i'm having a bugger getting my tach to work. I'd be interested in the tach and the sender for it.
Posts: 12 |
Vee-Berth fiberglass shelves - port and starbord? George
Posts: 58 |
Posts: 232 |
George: I have original v birth shelves. Will likely get them out this fall. Will contact you when I do.
Posts: 232 |
Pabs: The main is pentax with full battens. Was used for six seasons, maybe 100 times. Was stored inside. Good condition but has some significant stains.
162.5 was used 9 seasons. No delamination. It's OK.
155 was only used 30-40 times. IN very good condition.
