1,202,649 Dacron Main
233,637 Ananda's Refit
#17778 04/08/18 06:11 PM
C Offline
One of my hopefully down the road projects is dealing with my boom, which has a slight bend in it at the tang for the vang. It needs to be dealt with, but not before I put this boat back in the water soon. I think sleeving a bent boom would be very challenged. I was just looking at it and it would seem that all I need is the aluminum extrusion. Transferring the hardware does not seem like it would be overwhelming and I have the monster rivet tool and all the required tools short of welding equipment. So is tracking down this extrusion easy or hard? Is Rig Right my only option? I can also look for a used boom. Is the extrusion commonly available here on the west coast?
Which of the two boom types is this one?
Coastie #17779 04/08/18 09:26 PM
call jack at North Sails Seattle. He knows all the tricks. I had to do this job in Hawaii. The air freight cost more than the extrusion. I had an old crack under the vang tang that I never knew about. Part of the problem was that was the only piece f hardware that did not have lanocoat under it. The corrosion weakened the extrusion.
I'm not sure,but mine may have come from Hall Spars.
Coastie #17786 04/11/18 10:06 PM
i'd stick it in a tree and bend it back. We used to straighten dingy masts this way when they inverted during high wind races. They were just slightly smaller than the j30 boom.
