1,202,649 Dacron Main
233,637 Ananda's Refit
#17953 08/06/18 02:22 PM
N
N Offline
Has anyone else had an issue with the three boom screws holding the extrusion to the J-neck coming lose? I've been told that "everything" has been tried and I just need to check tightness periodically. I believe there must be a solution someone has come up with. Currently, my fasteners are stainless, phillips head screws.
Any thoughts?
J
J Offline
Try loctite threadlock.
U
U Offline
Drill, tap, bolt with locktite
Overdrill fitting and screw in stainless helicolis (threaded inserts).
Or... two (one on each side) can be thru bolted and held with a nylock nut
N
N Offline
No kidding? I haven't looked that close at the extrusion to see about access on the back side. Thanks!
