1,146,045 Dacron Main
212,918 Ananda's Refit
#18025 10/21/18 11:00 PM
P
P Offline
My Electrics have suddenly failed and I can't work out why. I gad an issue with my nav lights and i thought i had found the issue. When I went to turn them on everything switched off my panel appears to not be getting any power and I can't work out why as I have power going to my engine and peering the engine panel. Thoughts????
Pabs #18026 10/22/18 06:42 AM
There is a fuse holder buried in the harness near the battery switch on the output of the selector switch. It probably has corroded internally and needs to be replaced. Many boats have exhibited this problem.
Pabs #18029 10/22/18 09:46 PM
P
P Offline
Found it!! thanks so much also found that my navigation wire is toast. Do you know what cable I should use to replace it? 14 or 12 gauge?
Pabs #18031 10/23/18 01:39 PM
How much current does it take and what is the length of the run?
Pabs #18032 10/23/18 02:50 PM
P
P Offline
Its a 30' run in total and the lights are LED unfortunately I can't find what there current usage is.
Pabs #18036 10/24/18 08:26 AM
N
N Offline
I'm not an electrician, but I would go with the #12 wire...runs cooler, has less current drop over length, and can take a higher amp draw without resulting in excess heat or load on the unit. However, when in doubt, replace it with what was there if it worked that way for a long time.
Pabs #18037 10/25/18 05:54 AM
M Offline
Good point the best way to solve the situation is to replace it with what was there if it worked that way for a long time.
Pabs #18040 10/25/18 07:05 AM
If it is just LEDs you are more than adequate with 14 ga wire. Use marine grade tinned wire and run both the positive and negative leads.
Pabs #18053 11/03/18 07:35 PM
I had this fuse holder fail on Nordic Star also. Until it failed I never knew it was there.
Pabs #19197 05/11/23 09:22 PM
I'm not getting power to my engine panel (type B). Battery is reading 12V, but at key switch (off), I'm only getting 0.16V, and zero with the switch on. No buzzer or warning lights. Could this be due to a bad fuse holder as described in prior posts? There appears to be power to my interior switch panel.
