Posts: 24 |
Posts: 24 |
PRICE DROP TO $325.00 OBO!!
Posts: 41 |
I can only imagine that you don't have these anymore. I think I may need to replace mine.
Posts: 77 |
I have a set of pins if you need them. Let me know if needed and make a reasonable offer. Usa1136@yahoo.com
Posts: 41 |
Thanks, it looks like currently I need to reinforce(weld) a hairline crack in the upper rudder gudgeon, or replace that part. I'll let you know if the pins look questionable when I finally can remove them. Currently, the smaller security pins that keep the main pins from lifting out are refusing to come out. I hesitate to hammer them out lest I deform the security pin.
Posts: 2,685 Likes: 1
Posts: 2,685 Likes: 1 |
When I had Rhapsody I had a machine shop turn down the pins and drill out the gudgeons. He turned a pair of phosphor bronze inserts that fit between the gudgeons and pintals. This took all play out of it and worked great.
Posts: 41 |
Ah, interesting Bill. Is the idea that the bronze sleeves can be more easily replaced as a part that will wear over time while allowing us to reuse the stainless pin? I suppose that the bronze is also able to resist corrosion better with so much water present?
You are correct on all counts!
Posts: 47 |
Do you still have the gudgeons/pintles?
Scott Davis 704 900 9177
Scott Davis Night Nurse #363
