October
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
1,064 Registered Users
1,198,671 Dacron Main
232,487 Ananda's Refit
Members1,065
Hey all, I have a question about replacing the cam cleats for the traveler. My first mate and I noticed last week the teak blocks the cams are mounted to are really in bad shape and are about to rip out of the cockpit. We were in 8-12knts of wind then it suddenly built to 23knts, I went to let the traveler off and could see the screws barley hanging on. I saw a post here a while ago and it mentioned removing the old setup fill the holes and install swivel cams. has anyone used this, I can only imagine the reason for swivel is when I sit forward of the cockpit. I'm leaning more towards this idea. also if i do this will it affect the entrance for the NA next year in Bristol, we have been training all summer for that race.
J30 Heater Up #259
Ryan Scudder/Heat'er Up #259
You might want to include a photo of your current setup so we could give you the simplest fix, if that's what you're looking for.
I moved the turning blocks and cleats for my traveler so that I can use the full width of the traveler, added more purchase and used a single line so that we can trip the low side cleat after a tack.
Links to the images
http://ibb.co/qpnM4PD
http://ibb.co/4pRKxhy
I've improved small aspects of the system since first install (these photos), but am happy with it overall.
