J
J Offline
Hello everyone, I live in Santiago, Chile. I will try to express myself in English. I need a detail of the solution for direct discharge of water from the toilet to the outside. somebody could help me? Thanks a lot
G
G Offline
Jao,
https://www.westmarine.com/west-advisor/Selecting-a-Sanitation-System.html might be a good start.
Raritan is a well known manifacturer of many marine toilet components with some technical article https://www.raritaneng.com/blog/
But mere google search (https://www.google.com/search?client=firefox-b-d&q=how+to+plumb+a+marine+holding+tank) will give you plenty of hints.
In the US, you need a holding tank (you can not discharge in the 3 miles coastal zone, and there is many additional limitations), but most boats (including mine) usually have a dual discharge - since it is common to sail much beyond this limit - especially with a nice cruising boat like the J/30.
The vented siphoned loop is likely the most single important aspect of the setup... no one want to sink through their heads ... .
cheers,
-- Georges
-- Georges
J
J Offline
Thank you very much George
I am in a lake where there are no gray water extraction services at the dock and it is a problem.
For this reason, I want to install a second point of direct discharge to the outside, with a valve so as not to eliminate the gray water tank.
The links you send me are very useful to have an idea of ​​how to do it. If you can send me a photo of the solution in the J30, I would greatly appreciate it.
G
G Offline
Hi Joao,
...a business opportunity maybe ... just kidding.
I feel - no confidence there - that there was no production installed wastetank on the J/30 - so if you are looking for some 'reference' and a good one at that, unsure.
Foot Loose (1984 vintage) has a professional installation but I see its imperfections - I am actually considering changing at least the tanks and the hoses (smell).
I like the flexibility that my Y-valve set up gives me and my pump works fine - so will retain those...
The key J/30 specifics possibly are:
* waste tank - small (~15 gallons or so?) on the bow under the V-berth. Its venting with holes in the hull under the rail.
* vented loop - behind the toilet - inside the vanity compartment along the hull - up to the rail. If the boat is really heeled down to the rail - that might be iffy - but then it is likely it is not for long period of time, and the venting will take care of this transition :-) modern installation would probably have it closer to the centerline, maybe...
It will try to get you picture of my set up - it might take a while though - but again - not sure what you will gain from it that you did not get from the link I shared...
Cheers,
-- Georges
My 1982 J/30 came with a holding tank and Y valve. The toilet discharge can either go over board or into the holding tank.
J
J Offline
Thank you Rob
When possible please send me some pictures of your "Y" discharge system.
It's winter here, and I'm a 2.5 hour drive from my sailboat
I am asking from the boat parking to send me photos for my system
Joao,
I'll have to take some pictures. I'll be down at the boat next Friday.
Rob
J
J Offline
Thank you very much !! Rob
Here I send you photos of the installation I have, only with discharge to tank
Joao,
Here are photos of my setup.
Close up of Y valve. Handle removed, set to fill holding tank
holding tank aft end
Holding tank drain hose
Vented loop in anchor line locker
The Y valve left hose come from the toilet.
