October
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
1,064 Registered Users
1,198,671 Dacron Main
232,487 Ananda's Refit
Members1,065
#19172 04/05/23 10:39 AM
I have been trying to get measurements for my rigging to purchase a new spinnaker. The one thing that I kept seeing was the "Black mast band" I have a painted black mast and no band or any signs of a previous marking for one. Is this a requirement for NA's and if so, if I calculated right it should be 8 feet 8 inched from molded step.
Ryan Scudder/Heat'er Up #259
mjr Offline
Ryan,
Yes, the band is a requirement for the NA's. I'll send you the full measurement checklist for the regatta via email.
Mark Rotsky
Mark Rotsky
Nemesis 435
J/30 Class Measurer
J/30 Class Measurer
Ryan:
The measurement is from the bottom of the mast to the top edge of the bottom band and to the bottom edge of the top band. As follows:
Bottom of mast to the top edge of the bottom band: 2,698mm or 8.85 feet.
Top edge of the bottom band to bottom edge of the top band: 11,582 or 37.998 feet.
We do not measure these during inspection for the NA's but do check to see if they are in place.
Obviously, your bands should be white.
This information is available on the website under rules and specifications
Larry Christy
J30 Class measurer
J/30 Class Measurer
J/30 Class Measurer
Ryan
I believe the sailmaker wants the J measurement for your spinnaker.
Larry
Thanks for the info, I do not have any bands as the mast was painted black when i purchased her. Do the bands have to be painted or could i use white tape ?
J/30 Class Measurer
J/30 Class Measurer
Tape will work just find !
Larry
Moderated by  LChristy
