1,178,033 Dacron Main
225,511 Ananda's Refit
#5821 12/06/08 08:05 PM
OK, so I know the class rules show min and max size, but I still can't get my head around the quotes from 2 sailmakers at 98%
I could have sworn my favorite dacron #3 was a 105%.... somebody tell me what they have???? Maybe the dacron was never meant to be "class legal"
#5822 12/07/08 01:17 AM
Check out the following spreadsheet with class sail sizes: J/30 Class Sail Dimensions Use the LP/J ratio for % size
Here are the dimensions on a new #3 as measured when I accepted it from Quantum Sails last spring:
LP 3594mm = 11' 9.5" (spec 3550 - 3658mm)
Luff length 9955mm = 32' 7.9" (spec 9982mm max)
Using J=3505mm (11' 6") results in LP/J as measured 102.5%
LP/J Min and Max % ratios 101.3% to 104.4%
[This message has been edited by Rhapsody #348 (edited 12-07-2008).]
Rhapsody #348 #19446 05/19/25 08:55 AM
W Offline
Bill, the link to the dimensions spreadsheet is no longer working. Can you repost or email to bob.scott774@gmail.com?
Thanks.
watchoverya #19447 05/20/25 11:58 AM
I just fixed the link in the original post. Try it now.
0 members (), 44 guests, and 2 robots.
