#19477 08/05/25 09:53 AM
I wanted to start a thread as an open discussion to see who is making J/30 parts using a 3D printer.
Currently, I am working on a 3D drawing to replace the aging VDO Ocean series gauge instrument plastic bezels. The specification of the gauge is 52 mm in size.
Does anyone have a 3D file to print the bezel and lock below? I want to print both the bezel and locking mechanism on the gauge.
Thus is an interesting thread. While I don’t have a file for you David, I can report using 3D printed parts as compass covers and as a replacement winch handle spindle. Will post images soon.
Dominique Labrosse
Red Five, #92
I just whipped up a 25mm ruler so you can easily measure if the boat is in compliance with Class Rule 5.7.3 "[...] the
forward edge of the mast is not less than 25 mm aft of the forward vertical face of the molded step in the sole liner"
Here's a link to my Google Drive with a zip file of the STL, STEP, and SOLIDWORKs files.
https://drive.google.com/file/d/1QwK4XwWZrOmN4DzqT27LTyVcLcAw3aVw/view?usp=sharing
Oh, and also stanchion toppers to replace the crumbling zinc tops on my spare stanchions, these should be a pretty tight press-in fit.
