Page 3 of 3 1 2 3
#2012 09/26/08 06:56 AM
It will start depowering the main earlier and will impact light air sailing. Most sailmakers have their designs setup for the optimal sail shape starting with the rig in the correct position. With 15 kt trade winds shouldn't even need to start the backstay tension.
Since you need to pull the mast to adjust the base position, if you are not doing racing, you can wait until a convenient time when you pull the stick. Otherwise if you are racing, you are taking a performance hit.
#2013 09/26/08 08:38 AM
It being that far back is also effecting the center of effort but I cannot remember if this is creating more weather helm or less. Not enough coffee yet.
David
#397
[This message has been edited by dbows (edited 09-26-2008).]
#2014 09/26/08 09:42 AM
S Offline
it works like a windsurfer, mast aft and you turn into the wind, mast forward and you turn away from the wind. I moved the mast step from 2" off to the recommended 1" off the step, it made a significant difference in performance and increased weatherhelm.
#2015 10/10/08 07:15 PM
I measured mine the other day and it is 1 1/4"
Is it worth the effort of advancing it the 1/4"?
Page 3 of 3 1 2 3
