1,145,993 Dacron Main
212,831 Ananda's Refit
#2022 04/24/00 10:39 PM
dwl
Offline
So,we got our hands on a setof templates, slapped them in place and... The leading edge is slightly fat (about an inch behind the leading edge, it seems about 1/8 inch fat), and significantly (like 3/4 of an inch) short) I gather this is fairly typical. How much work is it to build out the leading edge, and how doe one go about it? Or does this fall into the evil category, where if you have to ask, you should dig out the checkbook and get a pro to do it?
- David
#2023 04/24/00 11:42 PM
On my boat the original fairing job had a piece of wood (about 3/4" square) added down the leading edge, then glassed over. The lower part was damaged over the years, so when I re-did it I used a stip of fiberglass instead of wood (it won't absorb as much water). Not rocket science, but time consuming. Especially the detail fairing once the shape was close. A pro could probably do it faster, but I've heard its costly.
Ed Austin
Chinook
#2024 04/22/08 02:10 PM
I'm starting to template my keel and I'm trying to take as many pictures as I can of the process.
Check out the site sailrattleandhum@blogspot.com.
WHERE CAN I OBTAIN A SET OF (KEEL) TEMPLATES?
I MANAGED TO "BUMP" OFF A TIP OF A LEDGE AT NO MORE THAN 1 KNOT
AND MANAGED TO BUST UP THE BOTTOM OF THE KEEL FAR WORSE THAN EXPECTED(IT WAS BRITTLE FAIRING COMPOUND FOR THE MOST PART),SO NOW THAT I HAVE TO REPAIR IT, MIGHT AS WELL MAKE SURE IT'S OPTIMUM. BOB CULLEN
"JEANIE" #63
63JEANIE #8731 01/09/10 12:11 PM
Bob - send a message to Mark Rotsky - Nemesis. He's got a set that many of us have used.
Bill,
Just shot out a request to Mark for bringing the templates to
Thursdays mtg & I'll trace copies on paper/not sure if he monitors his messages on a regular basis...so,is there a number I(or yourself if you don't mind)can reach him at before thurs?
I managed to find a phone # thru the internet "white pages",but
when I dial,get the fax/computer "screech"...We'll try to be there by 6:00 to see the sights! Thanks, BC
860-537-1085 hm 860-334-7641 cell
63JEANIE #8889 02/01/10 11:45 PM
Bob - Don't come Thursday, because the meeting is Friday! I spoke to Mark tonight and he'll contact you. I'll send an email with details.
