October
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
1,064 Registered Users
1,198,808 Dacron Main
232,514 Ananda's Refit
Members1,065
#214 09/02/00 11:35 PM
F Offline
I have owned a J-30 for the past 20 years, and last year I had ice damge to the bottom as a result of water in the balsa core. I have bben advised that this may be a common problem resulting from an inadequate seal between the exhaust pipe and the hull. If anyone has had this type of damage I would appreciate knowing what was done to correct the problem. ThANKS IN ADVANCE.
#215 09/13/00 12:26 PM
J
J Offline
We had a similar problem with a leak around the exhaust. We had a pro do the repair, which involved removing and replacing the balsa core on about the bottom 12 inches of the transom and probably about 2-3 sq feet of the bottom where the water had run down the transom and into the core on the bottom.
John Colpitts
Halifax
0 members (), 242 guests, and 5 robots.
