#2151 09/13/04 08:09 AM
C Offline
Hi
I know this is a bit like asking how long is a piece of string*, but if a J30 has high moisture levels at the deck fittings and a wet bottom, how expensive (Roughly) would it be to fix?
Thanks in advance.
Charles
* Twice the distance from the middle to one end.
#2152 09/14/04 07:17 AM
Charles - Can't answer your question but food for thought... What do you want to use the boat for? Who's going to to the work? How much time do you have to let it dry? Is there any moisture damage (i.e., is the boat actually unsafe)? Best to ask the opinion of someone who has done/can do the work. If there's little/no damage, then it can probably be dried-out and sealed with a reasonable amount of labor and dry-out-time. If there's mushy balsa and delamination (damage), the expense will be much higher. If you haven't bought the boat yet, you may find a dry boat is worth the difference in $. Good luck.
