#2300 04/12/08 04:43 PM
CAN106 has a new boom tube, fresh from RigRite. As I move the Gooseneck over from the old boom, I see that no less that 5 holes were drilled in to it - one empty, two with 1/4" rivets and 2 with a stainless bolt right across the midsection.
I have a chance to drill the minimum number of holes in the new boom tube....question is: what was the original fastener used for the Gooseneck?
Corey Glynn
#2301 04/12/08 08:07 PM
I think the original is the two holes with the bolt through the middle. Same as your old boom, mine has three additional holes and uses screws instead of rivets. I ended up putting in inserts (like helicoils but stainless) because the threads were stripped.
#2302 04/13/08 09:25 AM
They may have changed the setup over the production run. Mondial is Hull 215 and the boom extrusion originally had 2 screws which fit into tapped holes in the gooseneck fitting. Over time as the boom worked against the gooseneck, the holes became oversized. I drilled out the holes and substituted a long bolt (and nylok nut) which goes across the boom. This has never worked loose.
#2303 04/13/08 10:37 AM
Looks like I had a combination of both: started with at least two holes for machine screws and ended with a through bolt.
May as well start where I will ultimately end up...through bolt it is.
Thanks....
Corey Glynn
