1,203,266 Dacron Main
233,940 Ananda's Refit
I agree on the metric thread analogy for the temp sensor. Even though the block was made by General Motors (hence the 2GM moniker), the balance of the parts are designed & built by Yanmar using metric standards. Both standards are used on the engine, although the fasteners are predominantly metric. The socket set I keep on Rhapsody has both metric and SAE sizes to accommodate both. I highly recommend picking up something like a 24 piece SAE/Metric socket set and leaving it on the boat with other "emergency" tools. These have saved my bacon more than once when a needed repair was made underway, or while cruising.
I agree the in-line is not perfect but I searched everywhere and could not get a sensor that fit. Here is my rational for plan B - in-line. I had overheating issues and I wanted a guage to tell me if the temp was going DOWN once it overheated. The in-line does this. I knew temp guages are not accurate but just really wanted to know that the temp was going down - I really do not care that it drops from 120-110 or it shows 100-90 the fact that it is dropping is what I was concerned with.
Well I did a bunch of other work on the cooling system and thankfully I have not overheated since (-: so I have not been able to really use my guage.
David
#397
Originally posted by whitedolphin:
My Yanmar 2GMF overheated this weekend for the first time. Was running for about 45 min at 2000 rpm. Decreased to about 1000 rpm for about ~2 min, then went to idle forward to pull into the slip.
Just a moment before I really needed a lot of power to keep the boat off of the dock in some heavy Charleston current, the temp alarm came on and when I went hard astern, the engine noticably bogged down. A well placed fender prevented a lot of damage to a neighboring boat.
I've not ruled out the I simply just decreased the RPMs too quickly which didnt give the engine time to cool, but from reading various posts on this list, it looks like there are several common problems that cause overheating.
In the mean time, I would like to add an engine temperature gauge so that I can keep track of what is going on. I'd like to add the gauge without affecting the current warning light and alarm.
Is this possible or do I have to get rid of the stock temp sender to install a sender for the gauge?
If anyone has added a gauge - what parts did you use and where did you locate the actual gauge?
Hoping someone can save me some research time.
Dan M., J-30, "White Dolphin"
Sounds like you may have sucked something up the intake. I sucked a plastic bag over the intake grill once and it did a very similar thing.
David
#397
Good point David. And it does work in that sense. I havent overheated again yet (like you, I did some other stuff at the same time), but for example, If I'm running for a while and then throttle down, I will see the temp bump up from the low RPMs, then settle back down - so it is definately giving me useful information.
-dan
Dan - I had the same symptoms before I cleaned out the water passages in the head. The front cylinder was pretty much scaled up, and in some spots the scale had turned to hard carbon blocking the passages. I had virtually no water flow around it before the cleaning. I'd get the high temp alarm after slowing down subsequent to running higher speeds. The reduced flow from the water pump at lower RPM wasn't enough to take care of the heat that had built up.
I know you're fresh water cooled, but consider taking off the manifold that the thermostat screws into and see if there is any obvious build-up/blockage there. You also may want to check the thermostat and make sure it opens in a cup of boiling water.
Second thing I found after I rebuilt the engine was the water pump bearing going bad and finally seized. I replaced the pump and have noticed significant improvement in the water flow out the exhaust spray. I rebuilt the old pump and include it in a bag with my "cruising spares".
