#2758 03/18/02 11:36 AM
I've got "boat pox" showing through a three year old barrier coat job. By "boat pox" I mean clusters of tiny blisters on the order of 1/16" to 1/4". I stripped all the way down to bare glass in an area and found the gelcoat to resemble swiss cheese with tiny holes/bubbles where the blisters were. They are bone dry.
Any experience with this? Should I strip the whole bottom down to glass? If so what's a reasonable way to do this? I'm not doing it by hand. It's hard even using a random orbital sander!
#2759 03/18/02 01:47 PM
Mark, I've never repaired blisters but consider "West system" to be the definative word on all things epoxy. They have a "step by Step" manual availibe at West Marine for a couple of bucks if you have not seen it. I did strip my botton last season though, I used "Peel Away" ( see Practical Salior for review). Use the "home version" they sell at Home Depot, I'ts a third the price. Follow manufacurers directions. I was ready for the job to be a nightmare. It was not at all! I actually enjoyed it. I scrapped the paint into a five gallon bucket rather that letting it get on the ground. Eliminates clean up and environmently friendley.
#2760 03/18/02 05:44 PM
Around 1985 the original owner lightly sand blasted the gellcoat and let the moisture content dry to about 4 or 5 percent then applied (rolled) 2 coats of WEST. After a slight fairing a coat of cold tar was sprayed on. While the tar was tacky a coat of Balta plate was sprayed, dryed and wet sanded. For 15 years or so I did not have any POX. I just recently sanded opened the epoxy at the waterline due to a light POX and repeated the proceedure execept that I sprayed 2 coats of V.C.TAR prior to Batla plate. The new v.c.tar is very smooth unlike the old version.
