The side ports on my J30's cabin top appear to be UV-rotten Plexiglass. I am going to replace these with Lexan.
Anyone done this before? Any tips as to machining Lexan, installing, preferred adhesive/caulk material, etc.?
I am considering producing a drawing and having an internet/machine shop machine me up a set of 4.
regards,
Jack Curtis "Phat Cat"
I've just finished replacing three out of four this season; one more to go. I replaced them with plexi, but I figure in a few years I'm going to splurge on real opening portlights anyway, so the cost for lexan isn't worth it.
I removed the old one first to use as a pattern. It's just held in with caulk, which could be removed with unfortunate ease and the window pushed out. Getting the last of it out of the cabin top was a pain and getting the surface clean was a pain; I found copious amounts of acetone worked fairly well.
I then masked off the inside and outside of the cabin top, as well as the inside and outside of the window itself, with painters tape. I put a bead of cauk (The yard recommended SikaFlex which I used) around the inside frame, pressed the window in firmly, and then ran a bead of caulk around both the inside and outside frames. The cabin top around the two forward windows is slightly curved; I personally didn't find a problem getting the window to stay put and didn't need to resort to bracing it against a stanchion to bend the window.
Someone on this board recommended using a finger dipped in soapy water to smooth the caulk while it was wet; I did that, and it worked nicely. Then came the waiting game of peeling the tape off to leave a fine line. Too soon or too late makes a mess.
It doesn't look as professional as I'd like, and the SikaFlex seems to attract dirt, but I can see out the windows clearly and my water leak problems are gone, so I'm happy.
Ryan Pierce, #337
On the subject of machining....
With all the caulk that holds the window in place, I find it's difficult to get an idea of the actual window shape. I recommend removing one to use as a pattern rather than guessing with the window intact.
As far as I can tell, all four are identical in shape. Two are mirrored from each other. (Not sure if that is important; I don't know if Lexan has an indoor and an outdoor side to it.)
I personally used a jig saw to cut the portlights to size, fitted them, and used a sander to remove excess material where they would stick in the cabin top.
Good luck!
Ryan Pierce, #337
I replaced my windows about 4 years ago... with plex... and am getting ready to do it again... ALL of mine were a different shape.... had them cut approximate from a template then had to sand them to fit. I kept the original windows so this time I'll be cutting from them. Plex does not last in the tropics... it crazed within a year.
Go right for the opening ports. Lewmars fit nicely into the openings with minimal cutting.
The ventilation difference is amazing, you can add screens when cruising, and real glass never crazes.
I did mine about three years ago with polycarbonate. I scrounged around in the remnant bins at my local plastics supplier and found some with UV resistant coating that I got by the pound for about 50% of what branded Lexan cost. On his recommendation I lightly sanded the coating under where the caulk went (also SikaFlex...don't use 4200/5200..polysufide adhesives will eat the polycarbonate). I hadn't heard the "soapy finger" trick so mine look a bit ragged, but they haven't leaked in three years in the damp Northwest.
I see someone installed opening Lewmars? Do you happen to recall which port they were?
Thanks!
Doug.
Doug Marshall
Koeshtkah #207
B
B Offline
Re. side ports. After going through 2 sets of Plexi I replaced them with automobile safty glass
bedded with black sekaflex. Used the old ports as a pettern and had a local glass shop cut the new ones. They were all slightly different in shape . 2 seasons now with no leaks, no scratches and clear as a bell.
