#4019 05/07/03 08:43 AM
Hi,
does anyone know the length of the engine stop cable? I removed my from the boat to bring to the dealer for replacement and can't find it now... Thanks a lot.
Nick Dickey
J/30 Kamchatka
City Island, NY
#4020 05/07/03 05:30 PM
The shut off cable is a standard Yanmar Cable. They can be purchase at any Yanmar Dealer.
#4021 05/07/03 09:35 PM
They tell me there are three different lengths available...
#4022 05/08/03 08:20 AM
Length isn't critical. Just that it is long enough. Mine has lots of slack. You can estimate it with a tape measure, line, etc.
Good luck.
#4023 05/08/03 08:23 AM
Length isn't critical. Just make sure it is long enough. Mine has lots of slack. You can estimate it with a tape measure, etc.
Good luck.
#4024 05/12/03 03:48 PM
I just bought one two weeks ago from a Yanmar distributer, it was only $24. It's amazing how easy it is to pull. I was used to having to grit my teeth and grab with both hands.
#4025 05/12/03 09:08 PM
So how long is it? Mine currently terminates in the port lazerette. There is a hole near the instrument panel with a bolt in it I assume the cable was originally routed to. Is this correct? It seems to make more sense that upending who ever might be sitting on the port side of the cockpit to shut off the engine!
#4026 05/13/03 02:51 PM
I didn't measure it, I just told them it was for a J/30 and it fit fine with a little slack. The hole on the port side of your engine instrument panel is where the kill knob comes out. I can't imagine why someone would put that in the lazerette unless they bought a cable that was too short.
#4027 05/30/03 09:59 PM
Port lazerette, that's where mine is, original from the factory.
Dennis Bartley
Planxty, s/n 23994
hull 205
#4028 05/31/03 12:14 PM
dwl Offline
Likewise on hull 3. The stop cable lead into the back wall of the starboard locker. For that matter, I also pulled out an ancient engine
start switch from there as well.
- David
