Posts: 45 |
Anyone know a source for ANCO spinnaker pole end fittings for the 2.88" OD pole my boat was equipped with? Or a piston/spring rebuild kit for same?
It looks like standard pole diameters are 2.5" and 3.0" these days, so I probably need to find some used parts in working order.
Bob #326 Sophia
[This message has been edited by RobC222 (edited 06-25-2007).]
Posts: 4 |
I just broke my end fitting in an overnight regatta and am having the same problem finding a replacement part. Anyone have suggestions? Don R. #267 Originally posted by RobC222: Anyone know a source for ANCO spinnaker pole end fittings for the 2.88" OD pole my boat was equipped with? Or a piston/spring rebuild kit for same?
Bob #326 Sophia
Don Rassiger drassiger@gmail.com #267
Posts: 5 |
We had a plunger break on What If #325 a couple years ago, I took the other end to a machine shop. They made a new plunger fo $50 and it is still working.
Steve
