Posts: 32 |
My fuel tank is starting to seep. Can anyone give me the name, non-800 number, and email address of where I can purchase a new one?
#237, Panama
Posts: 137 |
I have a similar problem and found the manufacturer of the tanks and have a schematic drawing as well They are all at the office so I will give you the info Mon-Tuesday Mine appears to be leaking along the bottom aft corner... Taras Hull 532 BreakAway
Posts: 32 |
Thanks mucho .... my email address is herbertclifton@hotmail.com
Posts: 268 |
Me too please... jdoe(at)onebox(dot)com
Posts: 97 |
I have purchased a J-30 fuel tank from: Florida Marine Tanks. They have a facility in Florida and In Dexter, Missouri ADDRESS 16480 NW 48th Avenue Miami, Florida 33014 PHONE (305) 620-9030 EMAIL Info@FloridaMarineTanks.com If they or you need a sketch I have one with their price quote on it. It was $150.00 in 2001. I can e:mail a copy to anyone who needs one. [This message has been edited by whk (edited 10-04-2008).]
Posts: 2,685 Likes: 1
Posts: 2,685 Likes: 1 |
Jerry - If it is not proprietary, send it to me and I'll host a picture to display on the forum.
Tnx - Bill
Posts: 137 |
I can also provide a drawing of the tank in either an AutoCad or Pdf format Luther's Welding and Repair of RI (401) 253-5550 made the original tanks for TPI
If you are replacing the tank, how will you re-install it? Will you glass in new brackets to hold it or make some sort of strap system? I am considering the latter
Here is a link to the The Luther's Welding & Repair J/30 Fuel Tank Drawing in PDF format that Taras provided.
Posts: 32 |
Thanks for everyone's input. I finally went with Luther Welding. I paid $480 for the tank and $60 shipping to my freight forwarder in Miami. Because of the strange size and packing it cost $180 to ship by air to Panama --- a cost which was definitely breath taking. I have successfully installed it. I had to do some fiberglass removal over the old tank to remove it which took a bit of time and many cuts and scratches. The new one went in without too much work. Important note: the horizontal dimension of the fuel input pipe was about 2 inches too short to clear the bulkhead. I managed to get the hose attached, but it was a chore. The old tank had a non-electric fuel pump; the new one has an electric sender. I will hunt-up and new electric gauge this week. The Luther's Welding folks were helpful, timely, and efficient. Hope this helps anyone performing this chore.
Posts: 137 |
I also got a price from Boyd Welding LLc of florida $393 + shipping (352) 447-2405 boydwelding@bellsouth.net
