#5209 11/30/07 08:47 AM
Have to replace the U channel for the sliding hatch ... anyone have a lead on that plastic piece?
Vic
#505
PS If you pass through Naples this winter ... you are invited to an afternoon sail on Vee Jay.
#5210 11/30/07 09:59 AM
Vic - it's available from TPI. There's also an old thread here that discusses using aluminum channel you can buy at Home Depot. https://j30.us/ubbthreads/ubbthreads.php/topics/2374/Companionway_hatch_track.html#Post2374
Bill
#5211 11/30/07 03:56 PM
This is the second time in the last couple of months that "our old company" has kissed me off looking for our antique parts:
""Mr. Farmer,
Unfortunately we do not carry that part any longer.Regards, Isa Sanchez
Customer Service Representative
Pearson Composites, LLC
Phone: 401-247-1050""
I looked at the aluminium c channel at Home Depot and it just didn't look great ... will have to think about this some more.
Vic
#505
#5212 11/30/07 09:03 PM
S Offline
Barbour Plastics, Inc. have the hatch slides. http://www.barbourcorp.com/marine-products.htm
#5213 12/03/07 09:15 AM
Koos - good info. I looked around the web site and couldn't find it until I download the catalog. Vic - look on the bottom half of page 23 for the hatch slides.
http://www.barbourcorp.com/pdf/marine_catalog.pdf
Just another line on my to-do list for Rhapsody!
Bill
[This message has been edited by Rhapsody #348 (edited 12-03-2007).]
#5214 12/03/07 01:00 PM
A member of my crew machined some aluminum U channel for me. Looks great, doesn't break or bend like the original plastic.
Blue Meanie J/30 #485
#5215 12/04/07 11:35 AM
The PVC channel is about $2.50 a ft in 5 ft lengths ... BUT a $100 minimum order ... They are trying to find out for me who bought them last to see if there is a retailer.
we shall see ... somewhere we need to put together an inventory of parts ... one person with extra this ... one person with extra that.
Vic
#505
#5216 12/13/07 10:26 PM
G
G Offline
Does anyone have a pic of the aluminum on their boat?
Aluminum sounds nicer then plastic to me (as the plastic seems proned to braking) but there was mention of it looking bad.
#5217 01/02/08 02:43 PM
Contact TPI again, but ask for the J-105 plastic extrusion. It is the same as J-30 but about 3 inches longer. With shipping it is about $50 to your door.
Here is email quote from TPI's Isa Sanchez "We can send you two hatch slide extrusions (#32009)that we use on the J105s; I am not sure what was used on the J30s but you seem to believe it is the same part."
#5218 01/24/08 04:50 PM
I used some cheap aluminum channel from Home Depot and installed two years ago. Cut it to length and used a grinder/dremel tool to contour the cockpint-end to match the profile of the hatch around it. Looks fine and would send a photo but for the 3-4' of snow in the club's yard.
If you go this route, be careful to match the exact fastener size of the screws holding the aluminum in place - I inadvertently went a wee-bit larger and it cracked the gel-coat.
Also, take some time to *really* countersink the screw heads in to the aluminum - mine stick out slightly and it makes the hatch rattle when it slides.
If you're really keen to see the pics, let me know and I will snap a pic the next time I check on the tarp....
Corey Glynn
