October
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
1,064 Registered Users
1,198,808 Dacron Main
232,514 Ananda's Refit
Members1,065
#5248 02/15/01 12:00 AM
J
J Offline
Apparently we are missing a spinnaker sheet, which leads to an opportunity to buy a couple of new ones. What are people using, and is there any advantage ot the extra cost of a super-low stretch line?
John in Halifax
#5249 02/15/01 09:30 AM
John, low stretch sheets really do make a difference when beam/close reaching. The guy just doesn't "bounce" at all. With dacron sheets, the sheet would stretch and bounce against the headstay frequently. I think that I'm currently using T-900, which is a Spectra/polyester blend. It's also one of the most affordable of the high-tech lines.
#5250 02/15/01 10:35 AM
I agree that low stretch sheets defintely help. A local rigger made me a set of tapered sheets - bare spectra from the shackle back, then with fuzzy polyester cover for the part that goes around winches and ends up in the trimmers hand. I think Layline will make up tapered sheets as well. This avoids the hassle of having light and heavy spinnaker sheets (the way my boat was set up when I bought it).
#5251 02/17/01 12:18 AM
You can use the new Samson Warpspeed line. It has a spectron core with polyester cover.
The cover can be stripped off. Chicago Yachting and Navigation can make up these lines for you. Just ask for Charlie
0 members (), 242 guests, and 5 robots.
