#5619 08/01/05 03:16 PM
Hi,
My J/30 #270 has barient 10 winches as halyard winches. One of them failed over the weekend, and upon inspection, I found that the slot in which one of the upper pawls sits had been damaged (the tip holding the pawl in was chipped off) so that the pawl won't stay seated.
I spoke to someone at Oyster Bay Marine, and he said the drum isn't repairable or replaceable, and that I should buy a new winch.
First, does anyone know of a better solution?
Second, if not, does anyone have a recommendation as to a good replacement? It sure would be nice to find one that fit the existing bolt placement.
Rob Bjornson
Bayou Bleu, #270
#5620 08/04/05 01:45 PM
J/30 Class Measurer
J/30 Class Measurer
Rob -
A company in Australia was making parts for the winches. A list of replacement winches is available via Email.
Larry Christy
Natioanl Class Measurer
alchristy@comcast.net
#5621 08/04/05 01:45 PM
J/30 Class Measurer
J/30 Class Measurer
Rob -
Larry Christy
#5622 08/09/05 09:20 PM
I had a problem with my winches similar to yours. If I remember correctly I was able to close the gap where the paul fits through on the drum by carefully hitting the edges with a hammer thus closing the gap. My winches are still working it was about four years ago that I did this.
