#5660 06/04/00 12:24 AM
I have a 1980 J/30. When I top off the starboard side fuel tank with anything over
half a tank I wind up with fuel under the port side sink. I have no visable leak on the tank side nor do I have fuel in the bilge. Any ideas how the fuel might be traveling without entering the bilge.
#5661 06/04/00 12:39 PM
I'd suggest checking the fuel line from the tank to the engine, probably near the engine. You may have a small hole that only leaks when there is enough head (fuel depth) to push fuel through the hole. Any leak in the tank itself should go directly into the bilge. The leak may be originating near the engine sea cock (kingston valve) behind the nav station and running to port.
That's my best guess.
