#6053 02/04/05 10:20 AM
Has anyone obtained an IRC rating for a J-30? I am planning on racing some regattas this year that recommend having an IRC rating. If you do have a certificate, can I get some of the measurements from you? I know this won't get me an endorsed cert., but I think I can get away with un-endorsed for now.
Ed Austin
Chinook
#6054 03/03/05 10:57 PM
Here is a sheet created from J/Boats with the IRC numbers you will need. There is an IRC siminar this weekend a the J/Boat open house. Is there any questions you want me to bring up?
http://www.J/Boats.com/pdf/JBoat%20Standard%20RORC%20IRC%20Hull%20Data.pdf
David
#397
#6055 03/04/05 08:05 AM
Thanks for the info. This can help me fill out the form if I decide to get a cert.
#6056 03/21/05 08:33 AM
J
J Offline
I have a J30 in the UK and have raced IRC for the last 10 years with her. The 2005 endorsed IRC rating is 0.924 - We are reasonably competitive on this rating. A fractional J29 with inboard rates at 0.942 giving us 1.8 minutes per 100 minutes of racing. A J92 or X332 rates about 0.990 giving us about 6.6 minutes in 100. I hope this helps.
#6057 03/21/05 08:36 AM
J
J Offline
Additional information to that given above - I race with approx 147% overlap No 1 genoa - If you use 155/16% your rating will be higher.
