#6151 03/18/08 04:58 PM
Can anyone give me the Yanmar part number for the exhaust water mixing elbow for the 2qm15 engine in the J30? Thanks. #237, Panama.
mangomadnessj30.blogspot.com
Former Owner, Mango Madness
page 25 of the woodenboatshop hyperlink posted above
First two references don't have the elbow used in the J30. I found the last reference earlier but it doesn't specify that that is indeed the one that fits the 2qm15 engine. Can you or anyone confirm that this is the one used for the 2qm15?
I think Rob's info is correct. Check out this link on Torrensen Marine: http://www.marinedieseldirect.com/c...20EXHAUST%20MANIFOLD&quant_position= 0&catalog=Y00R0918&printparts=&printservice=&printoperators=&comment1=
[This message has been edited by Rhapsody #348 (edited 03-18-2008).]
I replaced the elbow on my 2QM15 last year. The Yanmar Part No. was 104214-13521, Elbow. I still have the box.
Ok - looks like the 2QM15 has the same variations as the 2GM. Some engines use a elbow with a 180 degree bend like the one Jim referenced (picture on Torrensen Marine) here: http://shop.torresen.com/ships_stor...ar&pn=104214-13521&storetype=mdd
Others have a smaller angle bend like the one that Rob referenced for Mango Madness. My 2GM uses and elbow with a 90 degree bend, and I've seen other 2GMs that have the 180 degree bend. There's a good picture of the 90 degree bend version here: http://j30.us/files/Rhapsody_Yanmar_Rebuild_Winter_2006-2007.pdf
So - determine what configuration your 2QM15 has for the elbow, then get the appropriate part based on that. Herb - If you have a picture send it along and we can help.
Rosebud's response answered the mail. Just ordered one from Torrenson which had a picture of the part. Thanks for everyone's help. Needless to say I recorded the part number for future reference.
That part number is the gooseneck, not the elbow.(104214-13521)(I guess it's the common replaced part, I just do the Mauratic acid flush thing)
[This message has been edited by MangoMadnesss (edited 03-19-2008).]
What did you guys use as a joint sealer on the exhaust coupling?
Vic
#505
