#6679 06/07/04 09:33 AM
What is the official ruling on Spin Pole Track - I read that some boats have the track installed to the deck. Mine stops a couple feet up, which means I must stow the pole elsewhere. I could set & douse faster if my track went to the deck.
Can I add track (per the class OD rules) ?
Thanks.
Dell Todd
#311 Temptation
Holland MI
#6680 06/14/04 08:19 PM
J/30 Class Measurer
J/30 Class Measurer
I did a survey of a number of J30's here in Annapolis several years ago. About 10% of the boats have tracks that go to the deck and this, evidently, is original equipment.
The decision was that if it was original equipment you can keep it but you can not add one or lengthen the one you have. Personaly, I do not see the advantage. It is more trouble sliding the car up and down than just lifting the pole up and cliping it on.
Larry Christy
J30 Class Measurer
Moderated by  LChristy
