#7079 03/10/09 01:28 PM
S Offline
Available from The Brass Works, Inc. PH: 386-943-8857, as used on the J100 and J95, part#4055-St.St.hatch lock, with hole for padlock, $37each.
[Linked Image from j30.us]
Hi Resolution Picture Download:
Open
Latched
I might have to get that
mangomadnessj30.blogspot.com
Former Owner, Mango Madness
S Offline
note of caution...some modification will be required on a j30 the images are from a j100 there is not enough room between the hatch cover and the locker to fit the lock on a j30
Be careful if you are working in the locker I do not think that latch can be opened from the inside.
Tom Bobbin
