Wondered if anyone knew of or has an extra Pushpit ? Located somewhere within the Northeast US would be optimal.
uh oh? Are you going to be able to race in PHRF NE?
You might try Tops in Quality. Not sure if they do pushpits. I take yours can't be welded locally? Over the years I've had the pads rewelded.
While ordering a new stanchion from "Tops In Quality", I discovered they offer J/30 rudder pins for approx $160 each. Their phone number is 800-414-2801. The J/30 knowledgeable person there is Gregg. The stanchion is about $70 +/-. On Nordic Star the top corroded away letting the top lifeline fall away at the gate. Based on comments from the Redhead this place seems to have the ability to supply some of our more obscure J/30 bits & pieces.
Jon - you can try Fraser Welding here in Marblehead - 781-639-1561
Thanks for the advice. Damage is not too bad. I will likely go the repair route. We are in for the PHRFNEs other then the fact that racing was cancelled for day 1 due to the not so tropical storm Danny. smile
