#7977 09/30/09 04:10 PM
My '86 did not come with a proper mast boot and with my present set-up I get traces of rain running down into the boat.
I have tried to order a new mast boot from RigRite since mid august with no success,....back ordered or something
Who would be the best source,....TPI or RigRite?
If it's back ordered at RigRite,...who are they getting it from?
Taras
_)
Taras #7978 09/30/09 06:59 PM
S Offline
I would recommend Spartite instead of a mastboot. The small kit should suffice. http://www.spartite.com/c-54-spartite-2000.aspx
sonskyn #7981 09/30/09 08:24 PM
In looking for J30 parts you probably will have better luck at Waterline than TPI who apparently no longer makes any Js.
Cap'n Vic #7989 10/01/09 11:08 AM
After years of using mast boot tape I did a version of this:
Ocean Navigator: A practical mast boot
Takes two properly sized stainless hose clamps which you can get at most hardware stores. Instead of truck tire innertube I cut up a piece of sunbrella fabric found in a boatyard dumpster. Three months and no signs of leaking.
